Old 17-03-2012, 09:52 PM
Default Mazdaspeed 6 (update: 1st August 2015 ) SN #12751 on onwards
Old 18-03-2012, 03:11 AM
Dust Dust is offline
Default Re: Mazdaspeed 6
Any idea if it will be similar or the same for the MS3?
Old 18-03-2012, 04:15 AM
http://www.mazdas247.com/forum/showt...-Function-List
ECU and other stuff for the MS3 gen1
Old 18-03-2012, 10:02 AM
Thanks for the link, I am working on all the drawings this week, it will be posted by soon.
Old 12-04-2012, 05:04 PM
Default Re: Mazdaspeed 6 (update) SN #12091 onwards
The H4 controller has been updated (see serial number). It is no longer necessary to perform one of the under-board modification any more, see old diagram.
For those who has the older version, please contact me for exchange of configuration upgrade. No charge.
Old 15-04-2012, 11:52 PM
silversport silversport is offline
Hi Richard,
I came here from the Mazda Speed forums;
I own a 2006 MS6 GT. I am in Houston Texas and want to purchase a kit for this car; it does not have major mods, that is a, SRI, a high flow cat, a balance shaft delete and the Hyper tech tune.
What exactly I need to purchase;
Regards;
silversport
Old 16-04-2012, 08:55 AM
As far as the water injection system is concerned, you just need a water tank. The HFS-4 has everything for your car.
What is your plan on tuning and power at present?
Old 16-04-2012, 03:43 PM
I plan to stay as it is at this point; but we do have long hot hummid summers here; thus far let just said I like to keep things clean and cool internally in this car; it has 29K, so the engine still petty tight allthoug I don't granny the car when I by myself,
Thanks,
ss
Old 16-04-2012, 05:47 PM
The system probably quite suitable for your application. It will mirror the fuel flow at any ratio. The consumption is quite low if you just want to keep things cool and minimise carbon build up on the inlet valve.
The system gives excellent atomisation from low to high flow due to its constant line pressure design. The dynamic range is very wide.
Old 27-04-2012, 07:55 PM
Aqua mist HFS-2 Injection System
Can I run this system on my ms6; I want to go with something solid and upgrade later; if I can list the size nozzle and the tap tool I need; I plan to just run my own tank (windshield washer tank) for now and do away with a truck set up in the near.
SilverSport,
