Old 05-05-2004, 03:42 AM
alpina alpina is offline
Default Adding a manual switch to disable pump?
Hey all,
I currently have a 1s system. Thinking of adding a manual switch to disable pump when the water tank is low. From the 1s instructions, it was suggested that the switch be used to disable the relay coil. This means to "break" up the wire that connects the 86/85 in the diagram below.
My question is, can I add the switch to one of the wires connecting to the pressure switch? eg, the green wire in the diagram?
Thanks for reading.
Old 06-05-2004, 02:33 AM
Nevermind. Got it.
Only way is to break up the purple line.
