Flow no more than 2 bars
I have hfs3 v2 installed in 08 sti.
All worked normal, all tests passed. My max IDC is 71%, threshold set to 28% IDC, but my flow meter not showing any more than 2 bars, I've tried to use gain trigger as so as SC on gauge with no results - still 1-2 bars even with 71% idc. Could it be |
Re: Flow no more than 2 bars
1. What jet size you are using?
2. Have you tried adjusting SC on the gauge?
2. Yes, we've tried SC, didn't change anything at all. In FIDC test mode I also see no morethan 2 bars. |
Questions please...
1) Can you tell me if the fuel injectors are standard factory 16 ohm type? 2) there is a small sticker on the left of the circuit board with three numbers, can youe tell what they are 3) how many bar is showing under SYS test?
1) Injectors are FIC 850cc HiZ
2) could tell later 3) sys without jet installed - full bars, with jet - 2 bars |
The system is working fine.
Justr need to deal with the bar display. Can you tell me what jet size are you using? There is a small sticker with three numbers on it. It i ssituated on the center-left of the circuit board. These number will tell me the flow sensor table.
1. one 1.0mm jet size
2. as I noticed by my WB sensor - meth spraying work as good as it should, total AFR drop is in ok range right where it should be when system is on, but I couldn't normally use safe feature with WL properly tuned because of only 2 bars flow on full load with 68% IDC. 3. Small sticker says SN: 100638 |
There is a smaller sticker just above it, with three numbers.
numbers: 12-135-150
This is highist flow sensor table.
1) Did you say adjusting the SC has no effect? 2) Can you put a 0.9mm jert (spare), let me know many bar this one displays 30 Do you knoe anyone has a PIC programmer? I can email you a lower flow table.
