Old 11-09-2012, 12:27 PM
Bikerz Bikerz is offline
Default Injector Sizing guide
HI all
I need to get a kit for my Audi TT. Im reading on here like mad, but any help would be great.
2.0 Lump 4x 750cc injectors
GTX30R76 4" Inlet
Pro Alloy FMIC with Large pipe work (80mm)
Standalone Managment
600 ish BHP I hope for.
Should I just run a single nosel after FMIC. I read that the only point in putting one before blower is if removing FMIC which I certainly wont be doing.
Any help or advice would be great.
Cheers
Sheldon
Old 11-09-2012, 08:08 PM
Mazda Carnage Mazda Carnage is offline
Default Re: Injector Sizing guide
http://howertonengineering.com/tech-...ating-jetting/
The examples on the page are older then the graph, just use the formula and chart and you will find your jet size.
The reason to run two jets is if your target water and or meth cc's are more then 1 jet can deliver you divide the # by two and run two jets that size.
