Old 06-01-2013, 04:22 AM
rom-vg30dett rom-vg30dett is offline
Default HFS-3 pump flow
Will the HFS-3 pump handle 2 x 1mm jets? I currently run 430rwkw @ 23psi and with the WI system I will maximise the turbos to 28psi. My injectors are 6 x 740cc and will hopefully achieve my goals with acceptable IAT's.
Thanks,
Chris
Old 06-01-2013, 10:16 AM
Default Re: HFS-3 pump flow
Yes, the HFS-3 pump is capable of delivering 2000cc per minute. It is limited to 1300 to 1500cc/min on the FAV.
6x 740cc/min or 4440cc/min of fuel at 20% W/F ratio requires a delivery of 888cc/min. water/methanol mix. It is well within the scope of the pump.
Old 07-01-2013, 01:00 AM
Excellent, thanks Richard
