Old 23-05-2013, 12:03 AM
Dean360Dallison Dean360Dallison is offline
Default help with my MF2
Hi i need a little bit if help. I have turbocharged my fiat punto 1.2 8v im using the standard management with the MF2 running extra injectors (fuel) I have 2 manifolds, 1st has 4 injectors Place next to each individual OEM injector (ie it has 8) and the 2 manifold has 1 placed just before the butter fly. I wood like to use the 8 injector manifold but the MF2 can't fire the injectors sequential, and if this doesn't matter and they can fire all together. how do I wire the 4 injectors to the MF2. Hope u guys can help.
Old 27-05-2013, 02:42 PM
Default Re: help with my MF2
If you are the MF2 as a fuel supplemental mode, you don't have to be too concern about single point or sequential multipoint as the air is entering the engine at a pretty high speed at medium to high load.
There is an instruction in the MF2 user manual on how this can be wired. Or download here:
http://www.aquamist.co.uk/cp/old/mf2manual.zip
