Old 04-06-2013, 09:33 PM
Awd_beast Awd_beast is offline
Default Hfs 3 v2 FAILSAFE question
I have evo x and about to wire up tephra alt map failsafe. Do I have to use relay with hfs 3 or is it just as simple as picture showes ?
Old 05-06-2013, 10:22 PM
Default Re: evo X Hfs 3 issue
Run it as the picture shown. The HFS3 has an internal relay to drop boost or tephra. No need to run both.
I prefer tephra.
Old 06-06-2013, 01:55 AM
Perfect so I dont need put resistor between white wire on hfs ecu harness to pin 115. Just resistor to the ground as per picture correct?
Also area I live in 200r are impossible to get...can I use 220r or perhaps 180r resistor ?
