Old 11-09-2013, 11:56 AM
M3GTttHulk M3GTttHulk is offline
Default Failsafe activated
After relocating my reservoir and pump to the trunk of my car I can't get the system to work when driving.
I purged the pump according to the procedure
I also activated the system using the jumpers and it is spraying
However when driving and hitting boost,, I get the Water level light and then the other light and no injecting. I can see the Bar indicator lighting up before.
Any ideas?
Old 11-09-2013, 11:06 PM
Default Re: Failsafe activated
Can you use the FDC jumper to confirm the system is seeing fuel duty cycle on the gauge.
Old 12-09-2013, 07:33 PM
Yes, I see both the green light on the unit as well as the S light on the gauge flickering with increased DC (reving the engine) but nothing else.
I have not fooled around with any wiring of the Aquamist, except moving the reservoir and pump to the trunk, but I am seeing a bit more boost now
When I jumpered the BAR I can see 3 bars
Old 12-09-2013, 09:50 PM
So far it looks good on the FDC link. The guage is displaying the fuel duty cycle.
Can you tell me how many bars are displayed at WOT? Only 3?
Old 13-09-2013, 06:20 AM
All of them at boost, just before the failsafe activates.
Also, the tank is full.
Would a leak in the system promt the failsafe, for exemples if one of the 4mm hoses was not connected? I'm just wondering if I should start tracing the hoses.
Old 13-09-2013, 07:44 AM
Good, the system is reading the engine load nicely. Please reinstate the FDC jumper back to the PRK position.
Once the system is set up to display 5-6 bars, a leak will be yield more bars and trip the failsafe.
OK, time to check the system once more for leak and set up the failsafe once more. You must check the spray pattern of the jet first.
Old 13-09-2013, 08:31 AM
I have 3 nozzles in total. My suspicions are that either of the pre-turbo ones are not working properly.
Since the 2 on the turbos are not easilly accessed I will disable them and use only the plenium one.
I will keep you posted.
Old 14-09-2013, 06:31 AM
Yesterday I turned down the gain to see what would happen and i saw the system working a bit longer before the failsafe kicked in. Points to the system flowing too much.. Probably a leak
Old 14-09-2013, 09:11 AM
Can you adjust the SC trimmer on the gauge?
This is just a short term fix. You really need to check the jets and locate any leaks and then set the SC.
Old 14-09-2013, 08:01 PM
Disabled the pre turbo jers and used only the plenium one. The system works perfectly. Looks like I have a leak on the pre turbo leg
