Old 07-10-2013, 06:08 PM
2.0t03speed 2.0t03speed is offline
Default HFS-3v2 wiring diagram Mazdaspeed 3
Hey i have a quick question about wiring up a v2 on my mazdaspeed 3. i have the diagram for the v1, but i need to know what to do with the extra di specific wire on the v2.
v1 diagram for the ms3:
v2 generic diagram:
Old 07-10-2013, 06:51 PM
Default Re: HFS-3v2 wiring diagram Mazdaspeed 3
I will make a drawing for the v2. It is different to the V1.
Old 07-10-2013, 06:57 PM
Thanks!!!! Also just fyi i have a gen 1 ms3
Old 08-10-2013, 09:06 AM
Just uploaded this one (gen1)... Let me know if it works with the v2 board. If you have the serial number, I can check.
http://www.aquamist.co.uk/vbulletin/...2407#post12407
Old 08-10-2013, 01:23 PM
the only problem i have with that is i think it's for the hfs-3v3. i don't have the user harnes for the idc sense and i don't see it mentioned anywhere in my user manual either. Now if i look at the hfs-3v3 w/ the red control board that would make sense as it has the idc sense user harness brought down from the hsf-4. the harness i have is just the the v1 hfs-3 only it has an extra yellow wire for di injector input.
i'll get the serial number for the box later tonight
Old 08-10-2013, 03:09 PM
I will post it up. I did it just in case you might have a v3 board.
Old 08-10-2013, 03:13 PM
If you have black circuit board (v2) without a green harness, it must be an earlier version. The DI decoder was still under development. You can return the circuit board to me for an upgrade to a later version of the v2.
Old 08-10-2013, 03:48 PM
Yep thats what i have black circuit board without the green user harness. i'm going to get the serial number tonight just so you can confirm everything.
Old 08-10-2013, 06:54 PM
The earlier version of the HFS3v2 is on beta test for the first few hundred or so. The green harness were supplied on request basis, help us keeping track on the progress on the DI specific applications. I believe 90% of the DI car had good results. The MS3 was a tricky one to solve at the time. Did you buy the your HFS3v2 from new specifically for the MS3?
Old 08-10-2013, 07:45 PM
No i purchased the kit used.
