Old 12-02-2015, 01:32 AM
lookback lookback is offline
Default New Build New Kit Mazdaspeed 3
I am near the completion of building my mazdaspeed 3. I needed a good WMI kit due to only having 91oct fuel around where I live. After working with Richard I will be setting up my kit for 200hp of fueling possibly more. I am creating this thread to show the power gains and a good install with pictures on a gen two speed 3.This thread will be updated periodically with install pictures and dyno charts of power gains from different mixtures and such.
The WMI kit I will be installing;
HFS-4 V3
5 Aquamist jet adapter 4 of them for port injection and one pre TB for cooling
5 .8mm nozzles to deliver the fuel I will need
1 T fitting
1 Hex Manifold
1 Aquamist WM tank 5 Liters with baffle and bracket
The motor build as follows:
Full machine work, pinning, keyed, port head, bore, the whole works
Carrillo H-beam rods
Gibtec pistons coated
coated bearings
and much more
Head was ported cams full valve job on 70lb springs with +1mm valves
PTE 5862 turbo kit full v band for the break in and base tuning.
Later to come in July it will be Twin charged with a TRD supercharger and a PTE 6466 Turbo this is where I was going to really need the fueling to stay up with the twin charge so with this build being said I will be posting pictures and keeping people updated.
