Old 05-08-2015, 03:18 PM
Aleibcas Aleibcas is offline
Default HFS-6 wiring for Volvo ME7
Hi all.
I'm trying to install an HFS-6 kit to my 2000 Volvo c70. Is there available any wiring diagram like the one I saw for a Volvo S60 and an hfs-3 kit?
Many thanks.
Old 05-08-2015, 03:27 PM
Default Re: HFS-6 wiring for Volvo ME7
You can use the same signal pins of the ECM. Green for fuel injector (-) and red for fuel injector(-).
Old 05-08-2015, 03:31 PM
Thank you for the fast answer.
Old 23-06-2017, 07:14 PM
Hello again. After two years, finally I decided to install the system.
Having everything in its place, according to the manual, the wiring you told me before and following the first power up instructions from the manual, water doesn't flow thru the flow control module. The flow stops on the inlet stage.
¿Is there any way to check that module or service it? ¿Could be any dirt stuck there, obstructing the valve?
Thank you,
Alex.
Old 29-06-2017, 06:35 PM
Finally I solved the problem, reading to another guy that had a faulty FCM in the HFS-6 forum. Then, testing the system, no bars got illuminated during the test neither on the road. Instead of that, the B gets lighted when the system is injecting, and with not too much pressure, I presume, since large drops comes from the injector and not a mist.
The yellow led is not lighted, so I suppose that it is not in fail safe mode. Any idea?
I also need to buy a flow restrictor, but they are not in the shop.
It is possible to find the 0,5mm one anywhere?
Thank you,
Alex.
