Old 01-03-2016, 01:08 AM
AliNowooz AliNowooz is offline
Default Aquamist and BCM Issue
BMW M6/F12
My car used to be running on JB4 and the aquamist was working like a charm.
I have recently moved from JB4 to BCM and since then the aquamist is not working at all.
Have anyone else had the same issue, if so please share any solution.
Old 01-03-2016, 06:38 PM
Default Re: Aquamist and BCM Issue
Who is BCM?
Old 01-03-2016, 10:53 PM
Mohammed Mohammed is offline
Boost Control Modual
Old 01-03-2016, 10:54 PM
BCM this is Boost control modual for burger motor sports..
Old 01-03-2016, 11:18 PM
Can you send a link to BCM?
Old 02-03-2016, 12:01 AM
http://www.n54tech.com/forums/showthread.php?t=31292
Old 02-03-2016, 08:32 AM
When you say it is not working, does it mean...
( I did some reading from your link)
1. The aquamist is not spray
2. You are not getting extra boost from the JB4/S2 with BCM
3. Does the latest S2/BCM module support meth at all?
Old 02-03-2016, 08:37 AM
Please post a hi-res picture of the controller board, I like to take a look of the settings.
Old 05-03-2016, 01:10 PM
The HFS4 reads the fuel duty cycle, it should not be affect by the BCM. All it does is to manipulate the boost signal into the ECU. Nowhere near the fuel duty.
It can work independently.
