Old 10-03-2016, 07:18 PM
Maktech Maktech is offline
Post Help please,HFS 4 V3 wiring diagram for E63 AMG
Hello ,
I am trying to mount HFS4 V3 kit to Mercedes E63 AMG biturbo ;
I could find a schema for CLS 63 amg,
They are almost same but some colour of some wires are different ,
I am worried about that ,
Does someone has any expreince about E63 amg (M157 engine) Biturbo ?
Old 10-03-2016, 09:54 PM
Default Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
Is your car a G63?
We have both diagrams.
Have you seen this one?
Old 10-03-2016, 10:14 PM
Is your car a G63?
Thanks but my car is E63 AMG biturbo , facelift one which has 585hp.
Old 10-03-2016, 10:28 PM
CLS is 4.4L bi-turbo and G63. I don't haver a factory ECU diagram for the E63, sorry.
Does the UCU look the same? If it does, I can 99% sure you can use the same diagram as the G63 and CLS63. I think the ECU is a small variation of the MED17.7.2
Old 11-03-2016, 12:43 AM
CLS63 AMG has the same engine with E63 , they both have 5,5 V8 biturbo;
Yes the ecu looks like , I hope we won't brake down the ecu or the Aquamist 😊
Thank you for the answers.
Old 11-03-2016, 12:54 AM
No, you will be safe either way.
Old 14-03-2016, 01:55 PM
CLS 63's and G 63's ECUs are Med 17.7.2
but my cars (E63) MED 17.7.3
I think becouse of that my system doesn't work proberly ,
I need to find the exact schematic of the ECU ;
I'll be thankful if someone can find it for me 😇
Old 14-03-2016, 06:19 PM
As far as I know. All you need to do is wire the red and green wire directly to the fuel injector. You can try the grey harness first. Let me the result.
Old 14-03-2016, 08:55 PM
Thanks Richard ,
You mean , we only wire red and green wites to the fuel injector without using map sensor signal , right ?
The pump is working when I start the system with the buton on the gauge ,
I hear the sound of working pump but it doesn't inject any liquid , the pump only works. I don't know what triggers to work.
Old 14-03-2016, 11:41 PM
Can you confirm the engine does not use direct fuel injectors.
