Old 15-03-2017, 02:06 PM
doc5339 doc5339 is offline
Default WMI SETUP RECOMMENDATIONS - 2011 AUDI A3 TDI
I have a high mileage (115,000 miles) 2011 Audi A3 TDI and I am looking for recommendations on the optimal WMI kit and setup.
The vehicle is a common rail injection 2.0 liter turbo diesel, engine code: CBEA, DSG transmission.
I would like to do a very clean install, possibly using the windshield washer reservoir, unless most of you think that I will need more water methanol?
I want to use -20 F windshield washer fluid as my water methanol mixture. Primary goals are lowering EGT, better fuel economy, and better performance.
Not sure if I should be looking at HFS-4 or another controller, also unsure about nozzle sizes and locations?
Thanks to all in advance for your comments and suggestions.
Old 10-04-2017, 07:10 AM
Macradiators Macradiators is offline
Default Re: WMI SETUP RECOMMENDATIONS - 2011 AUDI A3 TDI
Hi, i am interested in the same thing for the same engine.
Difference is i have big turbo + other mods in order to reach 320+ hp.
Hope somebody can answer and give some directions.
I intend to use 40-50% M to water or as advised.
Main goal is to keep EGT under control
Old 22-04-2017, 01:37 PM
Guess that we are out of luck, at least on this forum?
Old 06-10-2018, 10:34 AM
Can you tell me the engine code, the HFS4 should work with the common rail signals.
