Old 21-07-2017, 11:58 PM
Jroyalty7 Jroyalty7 is offline
Default Want to install custom meth plate
Hello,
I plan on installing my hfs4 kit with custom meth plates that need to be tapped for the injectors. I am looking for help/advice on what size checkvalve jets I should use, whether I need a compression or hosetail port option, and what size/pitch is used in order to update the manufacturer of the meth plates for my 2013 audi b8.5 s4. the link to the meth plates are here: http://sillyrabbitmotorsport.com/3.0...-injection-kit
I followed what I could from a previous s4 owners thread (infinkc) but with missing pictures and some descriptives missing I could really use some assistance please and thank you.
TIA for any help anyone can provide on this. My first meth/water kit install.
Old 22-07-2017, 12:10 AM
Default Re: Want to install custom meth plate
Also I am assuming I will need this manifold to run the 6 direct port injection nozzles?
http://www.aquamist-direct.com/806-4...-hex-manifold/
Old 22-07-2017, 07:14 AM
Ideally, you should get the DP bundle as it contains all the parts for a successful direct port installation.
http://www.aquamist-direct.com/806-4...his-shop-only/
Old 23-07-2017, 02:41 AM
Thank you for the reply and I will look into getting that kit from a local distributor. Another question regarding the hfs4 as I bought the kit used and it was previously on a bmw are there any changes internally I should make for the controller? Is there an audi b8/b8.5 specific install guide/manual available? I am concerned about the ecu wiring and making sure that it is correctly configured. This will be my first meth kit install so I am pretty green as far as the ins outs of everything. Thank you again!
Old 23-07-2017, 02:16 PM
My engine code is cgxc
Old 23-07-2017, 03:25 PM
What is the SN of the HFS4? I will check it for you can may post a wiring diagram if we have one. Which Audi model and year is this?
The controller should be OK if it is not hacked too much
Old 23-07-2017, 05:08 PM
Since this is a supercharged engine, we cannot implement the failsafe on this engine except cutting the ignition etc.. Here is the wiring diagram:
Old 23-07-2017, 05:58 PM
Hey Richard thank you for the reply, s/n is: 122169
Car is a 2013 s4 b8.5
Also I was thinking of running the 0.4mm jets 140cc for each port with a direct port injection meth plate, Im planning on running a bit more aggressive tune. That sound reasonable? Thanks for all your help
Old 23-07-2017, 06:22 PM
https://flic.kr/p/VMHssB
https://flic.kr/p/VMHrJx
Pics of the controller
Old 23-07-2017, 06:41 PM
Another question, I received the fav but appears to be missing the metal mount as shown in this pic:
https://flic.kr/p/WLc499
This is mine:
https://flic.kr/p/X29Sd8
Is this part sourceable alone or have to buy a whole new fav? Thanks again for your continued help!
