Old 03-10-2017, 05:11 AM
robos4 robos4 is offline
Default Need Help building water spray system with Aquamist parts
Hi all,
I already have a direct port meth setup for the combustion but I'm now trying to get the best water spray system to cool my car.
Hoping anyone here can suggest or help me out.
I track my car and it gets to 50deg C track temps, I have built 7 nozzles covering the intercooler, radiator and two of my oil coolers using 1.0mm jets from Aquamist nozzles (I also tried 0.5mm but it wasn't effective).
What would you recommend to use as nozzles, I don't feel the water spray is effective still or wide enough at high speeds
I now have a 160psi pump (almost identical to the aquamist pump) and a button to trigger it (simple setup). pics below.
The pump in these pics wasn't strong engouh (60psi) so I changed to the 160psi pump.
Old 03-10-2017, 06:50 AM
Default Re: Need Help building water spray system with Aquamist parts
Looks great!
I think you need to add an inline checkvalve to stop syphoning under gravity. Might empty your tank over night if the jet is below the water level.
Old 03-10-2017, 08:15 AM
Thanks Richard,
I did put one before we starting splitting the lines at the front of the car
What else do you think I could use for nozzles? I'm thinking I want a mist spray but one with a very wide spray angle 360 deg. the jets I'm using are only about 2" in spray pattern.
Old 12-11-2017, 09:03 AM
Raymond Power Raymond Power is offline
Perhaps should try directing the nozzles to spray at the opposite direction of air flow to the coolers?
Old 13-11-2017, 08:17 AM
Never thought of that good idea!
Will look into it, thanks
