Old 27-04-2018, 01:41 PM
Gunther Gunther is offline
Default Engine control unit to Aquamistcontroller
i control the Aquamist controller via a map sensor. Unfortunately, my engine
control unit does not get along when water is injected and therefore the
engine is not running properly. I would now like to use my engine control
unit to control the Aquamist controller.
Unfortunately, I find in the manual no way.
What can I do?
Gunther
Old 08-05-2018, 09:09 AM
Default Re: Engine control unit to Aquamistcontroller
what can i do with the AUX-Input options?
Old 09-05-2018, 07:44 AM
I need the following information:
1. Serial number of the HFS4 controller?
2. What car model do you have?
3. Why spray with boost instead of IDC?
Old 11-05-2018, 09:46 AM
Hello,
1: SN:121970
2: Lotus Elise Rover VVC Turbodrive
3: how the boost works was clear to me. I don't understand IDC. How can I set the power-on limit?
Gunther
Old 26-05-2018, 01:04 PM
now the system runs over IDC. But it's still the same problem there
Old 27-05-2018, 04:58 PM
Remind me what is the problem with IDC.
Old 28-05-2018, 06:31 AM
when I drive at full throttle and then take some throttle out the engine starts to ring through the throttle and the lower water flow rate. That's why I had to take the ignition back.
Old 28-05-2018, 08:48 AM
are you running M50/W50?
Old 29-05-2018, 06:05 AM
running with Methanol 60/Water 40
Old 29-05-2018, 08:34 AM
thanks for the answer.
Two more questions:
1. What is the HP of the car
2. What is the fuel injector size.
