Old 09-05-2018, 05:45 PM
pintovit pintovit is offline
Default Setup for a 300zx with DP
I'm building my shopping list to implement DP WI on my 300zx TT V6.
I'll be controlling the injection with my standalone and I'll be building my own tank.
Everything else, I need to get... So I made this list and I was hopping someone could point out if its correct, if I'm missing something or it contains something I don't need:
---- 806-400 ---- Direct port with 0.4mm 6x110cc jets - Std compression fitting
---- 806-239B ---- 1300cc Fast Acting Valve Fittings: 4mm+4mm
---- 806-249 ---- 4mm 15psi Checkvalve
---- 806-258 ---- In-tank filter
---- 806-259 ---- Hi-pressure inline 130um filter male/female 1/8BSP for HFS's (806-259)
---- 806-263 ---- 6 meters 4mm PTFE hose
--- 806-555 --- Replacement Flow sensor assembly Std (806-555)
---- 806-567 ---- Replacement Hall-effect Flow sensor cable
---- 806-581 ---- Replacement water level sensor
---- 806-582 ---- Replacement 160psi water pump
The basic idea is to have the pump turned on by the ECU (through a relay) when the system is active and then control the FAV using a custom table on the Link G4+
Thanks a lot for your time guys!
