Old 09-07-2019, 06:20 PM
BMC123 BMC123 is offline
Default SC display changes
Historically, I'd mash and hold the accelerator, the system would trigger and there'd be a gradual increase in the number of visible bars up to the 5-6 where I had it set it, using the dashboard SC trim. Now I mash and hold it and it goes right up to 5-6 (or more) bars and then drops off to 3-4 bars. It then begins to function as it used to, increasing as the engine makes it's way to the redline, showing 5-6 bars at peak. There don't appear to be any leaks. Any suggestions as to why it might be doing this or does it really make any difference? Thanks in advance.
Old 13-07-2019, 08:00 PM
Default Re: SC display changes
looks like you have air in the hose. Have you extended the hose between the FAV and jet recently?
