Old 23-07-2020, 10:39 AM
Gert_ Gert_ is offline
Default Error MF2
Hi, long time not been here (is good perhaps ).
But now a question. My (very old) MF2 goes on error. With power up, the system pressurizes and the led goes off.
Few seconds later, the led comes on again!
So, what is the diagnostic checking? Only pressure? Or other things too?
Anybody knows this?
Kind regards,
Gert
Old 24-07-2020, 07:16 AM
Default Re: Error MF2
It look as the system cannot sustain the set pressure, there is a small leak some where.
Old 24-07-2020, 07:35 AM
Thanks.
Disconnected the blue loom and switched on Ignition. For some reason the jet did not spray regularly, but after a few seconds she showed a nice continues spray.
So, I assume there was some air in the piping.
No idea why. Never had this before and remember, the kit is about 20 years in the car.
Old 24-07-2020, 07:52 AM
You could be right, air in the system will cause this.
Old 04-03-2022, 09:41 PM
Hi, anybody alive???
Anyway, my pump does not pressurize anymore.
Water is flowing to the pump, but if I power up, there is no water coming out off the pump.
I can hear her running.
How can I solve this?
Old 07-03-2022, 12:48 AM
manually inject some water into the pump with a syringe. I think the internal is dry.
Old 08-03-2022, 04:28 PM
I will try it this evening. But how can the pump get dry? There is an constant feed off water!
Old 08-03-2022, 07:37 PM
I urge you to try first.
Old 11-03-2022, 08:55 PM
Well, did not take much effort to succeed. :-)
Plugged power in and pump started to spit a little, what soon became normal flow.
Connected the waterlines and discovered that there is an leak at the manifold.
Pump is in the trunk and manifold under the hood in the front.
So, first I have to fix that.
But, I am still curious why the pump was dry?
Old 21-03-2022, 08:44 PM
Well, finally found some time to investigate the problem.
The on/off solenoid on the manifold is leaking badly.
I tried to find me some rubber gaskets that fit, but no correct size here.
Can you provide those, or a new solenoid?
I cannot find those parts on the ERL site.
