Old 11-11-2003, 03:36 PM
shoregtp shoregtp is offline
Default Need Part # for HSV so I can get a new one!
Hello,
I have attached a picture of my system and I am looking for a part number for the circled componets. They are the ends of the High Speed Valve. They screw into the high speed valve and its where you connect the hose into. ITS THE ITEM CIRCLED BLACK! Does anyone have any spares?
http://www.apisureshot.com/HSV.jpg
Gregory T. Forte
Old 11-11-2003, 04:42 PM
I am pretty sure this is the part needed -
806 363 - 4mm quick-fit to M5 male connector
It is unlikely anyone stocks this normally but I am sure any dealer could first confirm this is the part needed and second special order them for you.
Forumadmin
Old 11-11-2003, 07:26 PM
Just want to make sure its this item circled.
http://www.apisureshot.com/hsvd.gif
Thanks for the response.
Greg
Old 12-11-2003, 01:09 AM
That is the part that I am assuming you are looking for - and I think the one I listed is it but would need to double check.
Forumadmin
Old 12-11-2003, 09:54 PM
As confirmed by ERL the part number provided is the one you are seeking.
Forumadmin
Old 02-12-2003, 04:38 PM
Default Need new Part #
Need new part number.
http://www.apisureshot.com/gtp/mps.jpg
Its the circled item on the Manifold Pressure Switch. It holds the hose.
Thanks,
Greg
Old 02-12-2003, 06:32 PM
Brad Brad is offline
The part number is 806-364 it is a 4mm line to 1/8 pipe fitting and they ar $3.00.
Brad
