Old 12-11-2003, 09:03 PM
-=TWITCH=- -=TWITCH=- is offline
Default DIY water injection questions and ideas!
I have a 1995 eagle talon TSI with upgraded turbo on stock injectors and stock intercooler. I know I know but the turbo is running at low boost until more fuel and a bigger intercooler. I have made a DIY waterinjection system you can find info on my kit here. http://www.dsmtuners.com/forums/show...threadid=81892 I have not had a chance to really use the kit because I built the kit with a small 45psi pump what a buddy gave to me(that broke two days after install) I will be ordering a SHURFLO 100psi pump within the next week and will have the water injection up and running. My questions are does this setup look ok? Am I on the right track for a DIY water injection setup? as you can see I am using AQUAMIST nozzels and check vavles. just not using there pump and solenoid. What Can I do to improve my kit. what?s good what?s not?
Another question is there any way to make a DIY kit act like the AQUAMIST 2c kit? I would really like the kit to spray off the injector pulse width. Smaller amount of water at lower boost and RPM and more water at higher Rpm?s more boost. Is this possible, has anyone done this? I have a few more plans for my kit like a AQUAMIST flow meter to make sure that the system is working all the time.
Thanks for any help anyone might offer!
Chris
Old 13-11-2003, 03:23 PM
pbonsalb pbonsalb is offline
Default DIY H20
People have made their own basic kit and then used some Aquamist components. The better DIY kits use a good 100 psi pump. As you found out, its best to invest in a good pump from the start. Beware that different pumps tolerate different mixes of water and alcohol (or other fuels). Learn what your pump can handle if you are using it to flow something other than that for which it was intended. Contact the manufacturer.
Check the Aquamist parts list for the IID, which I think is the model with the high speed valve. I have not kept up on all the parts, since I got my system a couple of years ago. You may need only the high speed valve and the FIA2 injector driver to have flow follow that of the injectors, with a boost onset threshold. You then use nozzle size to alter max flow, so you might still need to verify your nozzle flow and you might need to obtain additional nozzles. More experimentation is required when you DIY. Once you go to the high speed valve, you might as well just use Aquamist nozzles since you will be using that size tube from the valve.
On www.turboford.org , there may be some info in the archives or elsewhere on making your own water injection. I know at least one person there built a nice system using the Aquamist high speed valve.
Philip Bradley
Old 13-11-2003, 06:06 PM
To make a variable flow system you basically need a solenoid that has a good reaction time and a high cycle frequency. Or alternatively a return line system that uses a multiplied rising rate regulator.
The aquamist high speed valve is a high frequency solenoid and operates like a fuel injector which is why some have been able to either run it parallel off an existing fuel injector's signal (make sure you isolate the signal properly and that the driver can support the additional current).
The fia2 will reference the fuel injector signal and then through a seperate circuit drive the hsv. This assures isolation and prevents too much current draw. The fia2 also includes diagnostics for the system though I am not sure how to implement them on the shurflo pump.
Normally the 2c or 2d would also involve a pressure switch manifold compared to the 1s however since you are using the shurflo pump the pressure is controlled via its own pressure switch and the manifold would not be necessary.
Forumadmin
Old 13-11-2003, 07:37 PM
Wow some great info. I just want to say that I use AQUAMIST jets already. I have a 1/4th water feed line that goes from my pump to my solenoid and then from the solenoid I use AQUAMIST line a jets. The solenoid I have is awesome it has a pretty big orifice size allowing water to flow very well. It also has a very fast response time. So now that I am using AQUAMIST lines and jets what do I need to make my kits a 2c? I know I will need the high speed valve. One more quick question my injectors are low impedance. And I was under the impression that the HIGH speed valve will only get a signal from HIGH impedance injectors? Is this correct? I also herd that there is a new product that will amplify my injector signal allowing the HSV to read my injector pulse has anyone else herd this? Please let me know and thanks a lot for all the great information! has anyone made a DIY kit like a 2c kit?
Chris
Old 13-11-2003, 08:07 PM
The fia2 is the amplifier you need to run the hsv off your injector signals. It will read your peak and hold type and then run the hsv.
So with the fia2 and a hsv you should be in good shape to set your system up for a variable flow rate based on fuel flow.
Forumadmin
Old 14-11-2003, 01:42 AM
Are those part made to only work with the aquamist pump? How would I make them work with my setup?
Old 14-11-2003, 05:35 AM
I would need to think about it some. I will PM you when I come up with something it will be before Monday.
Forumadmin
Old 14-11-2003, 05:57 AM
Thanks a lot for all your help!
Chris
Old 16-11-2003, 01:34 AM
The fia2 and hsv can be made to work with your system in a manner similar to the 2d. There would be two main differences the fia2 checks for blocked jets and cut hoses would not function and your boost switch logic would need to be changed through a relay but it is possible to integrate with your components.
Forumadmin
Old 17-11-2003, 04:07 PM
Brad Brad is offline
All of the information you have receive above is correct. The only issue in your design is the size of you accumulator. It is to small it will cause you pump to cycle to quickly and distroy the armature of the pump. What materieal is your pump diaphram made of there are several choses?
Brad
