Old 06-09-2004, 11:08 PM
turbor850 turbor850 is offline
Default Installation Question
Hi, I have just recently purchased my 1S system. I was just pre installing everything and when I put the tube for the water source to the pump (where the orange thing is) it went in and is now stuck, it has just a little play to it, but won't come out. Will this cause any problems ? Will this leak when the pump is pumping water ?
Thanks !
VOLVO 850R
Old 08-09-2004, 08:18 AM
dc96819 dc96819 is offline
probably not,
Old 08-09-2004, 08:37 AM
janis janis is offline
Default Re: Installation Question
Thanks !
The side of the pump where the orange thing is is the output, to the injector.
If you push the orange thing down a bit, you can remove the hose.
The play is normal and it probably woun't leak there. Make sure it's pushed in all the way (which isn't far) at final installation
Janis
