Old 15-09-2004, 12:06 PM
Gelf Gelf is offline
Default FIA 2 - 2 pumps and 2 HSV's
Will the FIA 2 in the aquamist 2d kit run 2 pumps and 2 HSV's ?
Old 15-09-2004, 06:24 PM
It may not be necessary to use two HSVs as one HSV will outflow two 1mm jets.
The twin-pump system may require a surge arrestor to stablised the
"beat frequency" generated by the two pumps running near 50Hz.
The image below shown a simple solution, two pumps feeds into one
5-port manifold and the accumulator will take care of the beat
frequency- the system run extremely quiet and smooth.
Old 15-09-2004, 08:02 PM
janis janis is offline
OMG, that's not a waterinjection system, It's art!
Old 15-09-2004, 09:29 PM
"beat frequency" generated by the two pump running near 50Hz.
The image below showed a simple solution, two pump feeds into one
5-port manifold and the accumulator will take care fo the beat
frequency- the system run extremely quite and smooth.
Thanks, i was thinking that two pumps each with its own HSV, could be activated at seperatly at different times, using separate pressure switches. Do i need two FIA 2's or would one do the job ?
Im looking in to injecting pre turbo and at the throttle body.
Old 15-09-2004, 09:54 PM
I was trying to save you money.
Yes the FIA2 can just managed to drive two FIA2 but need to keep it in a cool place.
The Fia2 is not too expensive an utem to buy. It is available separately.
Old 15-09-2004, 10:02 PM
Cheers for that I was also concerned how much current two FIA 2's would draw from the fuel injection loom ?
Old 15-09-2004, 10:11 PM
Slump Slump is offline
Richard -
What's the "jar" for?
I keep seeing all this amazing looking stuff that I had no idea existed.
I'm getting all excited to redesign my injection system and mount it all to a sexy bracket, etc.
Old 15-09-2004, 10:16 PM
The FIA's detection wire (green) will only draw about 1mA from the pulsed wire. You can connect the Red wire to a switched +12V source so that it wouldn't need to draw any power from the injector's positive feed wire. (only possible for non "Peak and Hold") circuit.
Old 15-09-2004, 10:37 PM
Originally Posted by Slump
Richard -
The jar is to store some temporary water (about 100cc) in the event of the main tank is low and subject to water surge.
There are three ports in the bottom, one in and two out (for the two pumps). On the top, there is a port to allow air to vent back to the main tank. For this system to work, the main water tank has to be at a higher level than the jar.
see picture below:
The car is one of our development prototype system for a tuning company, we will try everything to avoid the tank running empty or allow the system to stall when air is trapped in the system. You will see there is a high-ish water level sensor on the side of the tank, once the water get below that point, it stops the entire system working and a little dash warning led lights up - time to refill!
Old 15-09-2004, 11:59 PM
Cheers
Ive yet to investigate whether i have peak and hold injectors, its a vauxhall Astra G if anyones in the know ?
