Old 11-10-2004, 09:34 PM
spooldup spooldup is offline
Default How can you identify each nozzle and how many can you run?
I have the 2d system but only the 1s part of it is connected right now. I stuck one nozzle in and it works great. I am up to 20psi on race timing with no knock spraying 100% meth with klotz. My questions are how do you know wich size nozzle you are using? How many nozzles can effectivly be ran ran on one pump?
Old 12-10-2004, 05:33 PM
JohnA JohnA is offline
Two nozzles mate.
Do a search, there are a few relevant threads around here.
Cheers,
John
www.max-boost.co.uk
Old 13-10-2004, 12:11 AM
We have now a 0.3mm nozzle that flows approximately 75cc/min at 6 bar, one aquamist pump can run four of them and produce excellent atomisation.
The jet has an internal 25 micron filter but still advice you to purchase a main inline 30micron filter down stream of the original 100 micron filter.
It was designed for port injection applications.
Old 18-11-2004, 11:06 AM
ubcnme ubcnme is offline
Default aquamist jets
Hi Richard whats the part # for the .3 mm aquamist jets I want to run 4 of them in my veh. I want to do a port water injection type of set up. where can I order the jet at I have a hard time finding it on the internet. :lol:
