Old 20-10-2004, 02:17 AM
blacksrt4u blacksrt4u is offline
Default what size nozzle should i use
i am planning on getting a water/meth kit for my srt-4. i run about 19 psi on the stock quick spooling turbo. I also run a 75 shot of n2o. I am looking for a nozzle size that will give me a happy medium...not too big to where it stutters at 10psi and not too small to where im not getting a good benefit at 19psi.
should i go with a nozzle on the bigger side and just have it activate later so i dont get any stuttering and will benefit with the high boost and n2o??
I estimate about 350whp on the n2o and about 270whp w/o n2o....
i dont wanna do a dual stage kit becuz i just wanna keep it simple and not have all kinds of nozzles in my charge pipe..
Old 24-10-2004, 10:55 PM
I suspect your setup is a shurflo pump system, I need to what nozzle you are usin gand may be a simple test will clearify the flow rate of each jet. It is quite simple to perform, just measure the quantity of water after one minute. You can weigh the water - 1kg = 1litre.
Once I know the flow rate of the setup, I should be able to suggest some figures.
