Go Back   waterinjection.info > Injection Theory (what it is and what it does) > Fuel and Oxidizers
Old 11-11-2004, 02:32 PM
dc96819 dc96819 is offline
Default Fuel
What temp does 91 octane ignite at or does it need an open flame?
If fuel is injected before a compressor wont bad things happen.
Old 11-11-2004, 03:39 PM
Default ignition of fuels
Ignition of fuel vapors in air is very hard to define, it is strongly effected by the conditions of the sample, ie the size of the volume, the shape and construction of the container and the nature of the heat source.
Ignition of vapors is much more difficult with general heating vs a small concentrated heat source like a spark, flame or hot surface.
The minimum ignition temperature of methanol in air is 725 deg F, ethanol is 689 deg F, and gasoline is 824 deg F.
Old 08-05-2006, 12:01 AM
simple simple is offline
I acctually build a motor long time back using turbocharger off the disel engine.
I had carburator before the turbocharger. All worked great but you cannot have intercooler as it will separate fuel. However this set up makes the motor run very smooth under light to heawy load due to good fuel atomazation in compressor and even distribution. There is also no need for blow off valve. I belive this is a great set up and WI system will work wonders on it.
Old 11-01-2011, 03:47 AM
juliadesusa juliadesusa is offline
Default Re: Fuel
Fuel is useful thing,The thing is that there are so many types of the filter of the fuel.The motor is the useful thing for the fuel,For that your Quality of the motor will be good enough,And worked very smoothly.So that you will get the more benefits.
printed mugs
Old 12-01-2011, 10:58 PM
keithmac keithmac is offline
Default Re: Fuel
Renault 5 turbo`s used to mount the carb before the turbo as well.
Old 15-01-2011, 08:18 PM
Default Re: Fuel
No they didnt. R5's blew through the carb
Old 09-07-2011, 07:22 PM
1991Volvo 1991Volvo is offline
Default Re: Fuel
ford put the carb before the turbo and it worked grate, WI on a setup like this will just kill it like some one said up there^^^^
Old 16-09-2014, 07:56 AM
Canyata Canyata is offline
Default Re: Fuel
1991volvo is telling truth...... I have the same thing to tell
Graduated from Soran University with First Class Degree with Honours in Computer Science.
