Old 20-11-2003, 08:49 PM
AaronC AaronC is offline
Default Freezing Point - Best Mixture
Does anyone know what the Freezing point is for a 50/50 Methanol-water mix?
Also, what is the best mixture for performance? 50M/50W? Or would a 25M/75W be better?
Old 20-11-2003, 09:20 PM
Well, I found some info on this and I thought I would share:
Methanol \ Water Mixtures
Methanol Conc.
Wt. % (Vol.%)---Freezing Point,F(C)---Flash Point, (TCC) F(C)
0(0)--------------- 32(0)--------------- No Flash
10(13)----------- 20(-7)-------------- 130(54)
20(24)----------- 0(-18)-------------- 110(43)
30(35)------------ -15(-26)------------ 95(35)
40(46)------------ -40(-40)------------ 85(29)
50(56)------------ -65(-54)------------ 75(24)
60(66)------------ -95(-71)------------ 70(21)
70(75)------------ -215(<-73)---------- 60(16)
80(83)------------ -225(<-73)---------- 55(13)
90(92)------------ -230(<-73)---------- 55(13)
100(100)---------- -145(<-73)---------- 55(13)
Isopropanol / Water Mixtures
IPA Conc. Vol. % (Wt.)--Freezing Point, F(C)----Flash Point, (TCC) F (C)
0(0)---------------------- 32(0)------------------ No Flash
10(8)--------------------- 25(-4)----------------- 105 (41)
20(17)--------------------- 20(-7)----------------- 85 (29)
30(26)--------------------- 5(-15)----------------- 75 (24)
40(34)--------------------- 0(-18)----------------- 70 (21)
50(44)--------------------- -5(-21)---------------- 65 (18)
60(54)--------------------- -10(-23)--------------- 65 (18)
70(65)-------------------- -20(-29)--------------- 65 (18)
80(76)-------------------- -35(-37)--------------- 65 (18)
90(88)-------------------- -70(-57)--------------- 65 (18)
100(100)------------------ -130(<-73)------------- 53 (12)
Old 21-11-2003, 03:39 AM
Brad Brad is offline
Good information. The mixture for best performance is based on a combination of air fuel ratio and temperature of air being cooled.
If the engine is running 12/1 a/f and has a manifold inlet temp of 200F water is best. If you have a a/f or 13.5/1 with 200F manifold temp them a mixture a methanol would be in order.
If you have a intake manifold temp of less than a 100F a higher consitration of methanol would be useful if you can adjust the fuel ratio.
There is not one ratio that is correct for every application. You will need to test to find you best balance.
Brad
Old 22-11-2003, 08:49 PM
AKWRX AKWRX is offline
The mixture freezing lists above appear to have been sourced from data using chemically pure water. Pure water with no ice nuclei to start the freezing process can be chilled to -40 before changing state to ice. In the atmosphere it is not uncommon to have "super cooled" unfrozen pure water at -15F, or colder in clouds. In the real world, alcohol/water mixtures contain many other contaminates that act as ice nuclei, so the practical freezing points are not nearly as cold as those listed. For example, windshield washer fluid with a 50/50 mix of methanol also has detergents and other particles that serve as ice nuclei. The actual freezing point would be closer to -20F, rather than the listed -65F. I have observed an 80/20 mix of methanol (in a not too clean can) cold soaking outside to have the water visibly start to slush up at only -70F. Also, note that there are typos on the methanol freeze points for the 70, 80, and 90 percent entries (100 degrees off).
Old 23-11-2003, 10:07 AM
JohnA JohnA is offline
Very useful information Aaron, I was actually looking for it!
I'll use these tables on my website, if you don't mind :lol:
Cheers,
John
www.max-boost.co.uk
Old 24-11-2003, 04:11 AM
Good comprehensive and informative site too.
Forumadmin
Old 24-11-2003, 04:35 PM
He he...thanks
Cheers,
John
www.max-boost.co.uk
Old 01-04-2004, 10:50 PM
boostm3 boostm3 is offline
Heres the problem I found this winter. Here, we had frequent bouts with temperatures well below 20 degrees F. When it got down to near 10, I found that even a 45% methanol mixture, while remaining liquid in its reservoir, would ice up within the 4mm nylon lines. It never burst, since I believe most parts of the system remained liquid, but it wasnt thrilling to see the ice in the nylon lines Ill tell you! I just think that in these very small lines, it can be extremely hard to keep things liquid down below 15 or 20 degrees F. At least, with most of the system remaining liquid, overall there were no problems.
Paul E -
'99 White M3; < 69K miles; Dinan SC kit with 6" RMS crank pulley and water/air Aftercooler: 11 psi-367 SAE rwhp/304 ftlbs; Custom Tuning by Nick G; AA Aquamist Water/Methanol Injection and AA exhaust; Fikse FM-10s;
Old 06-11-2004, 04:52 PM
This site has a very comprehensive account of all the screen washer mix and freezing point tables.
http://www.ashchem.com/adc/chemicals...=3&is_header=N
Old 08-12-2004, 10:04 PM
masterp2 masterp2 is offline
I have just an educated feeling about this. A water/meth solution, loses the meth to evaporation 4x faster than water, so, with time, the solution is weakening, hense the greater likelihood of freezeup. Factor in frequent heatups inside the engine compartment, this is a reasonable explanation.
A small amount (line) will freeze sooner than a large amount as the temps swing. Ice cubes in the freezer are the same way.
