Old 04-04-2005, 04:05 PM
XX4me XX4me is offline
Default Straight waters effect on the A/F of a wideband O2 meter?
I've read most of the posts here and can't find what effect the WI has on wideband O2 meters.
Example being if I'm running an A/F of 12:1 without water will it remain the same with water.
Old 04-04-2005, 06:54 PM
We have touched on thsi subject many times but nothing too conclusive - is it possible to tune for 12:1 first and add water later and see if you notice any changes.
Old 05-04-2005, 12:10 AM
Unfortunately I can't without getting unleaded race gas.
I'm running 18psi on 93 octane pump gas with an intercooler and H2O injection.
Old 06-04-2005, 09:47 AM
You can turn the boost pressure down to 10-12psi and try it, the lambda will not notice the change of boost pressure.
Old 11-05-2005, 02:46 PM
tici tici is offline
I tried with my blowed 5.7L LS1 engine (6 PSI Vortech) and I saw no difference with or without water.
Right now I'm tuning that way for 12.5 AFR, then I'll switch to 50% alcohol.
Water alone allows a certain pressute/timing being on the safe side.
98 Convertible Trans Am
MODS: SC raptor hood, 35th decals, Vortech V9 G-Trim SQ, homemade water-alcohol injection, Corsa catback, Eibach springs
DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
