I have the 2d system on my supercharged tacoma. I'm currently using the 0.8 mm nozzle. It takes forever to go through a tank of water. My truck is street tuned tp 11.8:1 while in open loop mode. Is there a guide on how much water I should be injecting or basically try and error?
Thanks. |
How big is your tank and how boost are you running?
Thank you for your reply. My tank is about 1.7 gals. I'm running about 9 psi. Aquamist is set to start injecting at 1 psi. Thanks, Jim |
