Old 01-02-2004, 04:03 AM
TurboGTi TurboGTi is offline
Default METHYLATED Sprits can this be used?
OK i know we can inject methonol and alcohol ....
but i'm curious what about methylated sprits..!
its easier to get than pure methonol..!
will it affect the internals?
will it do any damage?
or better yet will it work!!
Keep it real
Microtech LT-8 ECU
Hugh Gordon
Old 01-02-2004, 05:55 AM
Methylated spirits as I understand them are almost straight ethanol with just enough methanol to make it poisonous to ingest. Use of them would be dependent on which system you are using and its tolerance for ethanol content. Ethanol is not compatible with Aquamist products for instance.
Ed.
Sponsoring Board Vendor
Old 02-04-2004, 08:04 AM
tomcat tomcat is offline
Why does it cause more corrosions ?
Old 02-04-2004, 10:22 AM
Default ethanol vs methanol
Actually in a generic sense, ethanol is less corrosive than methanol. The Aquamist simply has some components ( I believe seals) that are less tolerant of ethanol than they are of methanol. Rubber and other elastomers have different tolerences for the various alcohols. Each seal material will swell a small amount with each type of alcohol, some more than others. If a material swells enough with one alcohol that it is not recommended, it may be perfectly safe with a different alcohol.
Methanol has a higher oxygen content and latent heat of evaporation than ethanol, but ethanol has other advantages, such as lower toxicity (important in submarines) higher energy of combustion / pound, etc. so in practice they are very nearly identical as far as performance is concerned. One of the reasons the military settled on methanol in aircraft, was to keep the GI's from diverting it to other uses
In the pacific theater, the high test ethanol used in U.S. Navy torpedos frequently ended up being used for "pseudo medicinal uses". The gyros on the torpedos were cleaned with high grade pure ethanol. It was also used as the fuel in Mark 14 and 15 torpedos in their hybrid compressed air alcohol propulsion system.
This ethanol was called "torpedo juice" and also ended up being used for WI systems on the fighter aircraft, when methanol was in short supply (which was common in the early years of WWII). WI is called ADI in the aircraft industry.
In the early days aircraft mechanics would use deicing alcohol which was isopropyl alcohol. This alcohol was not compatible with the ADI metering settings and resulted in blown engines. The word came down from Pratt & Whitney to use only methanol or ethanol in the ADI systems.
Old 02-05-2004, 05:19 PM
Boosted Boosted is offline
Default Mineral Spirits WHOOPS!!!!
After seeing that methalnol spirits are the same a denatured alcy i went to the hardware store a was looking and seen mineral spirits and all i could remember was the word "spirits" so i bought it Mixed it 50/50 and poured it in my tank, well....i could swer that it was giving me MORE knock than with it off!!!! I guess i need to pay attention more to what i read.
Old 02-05-2004, 11:24 PM
Default Arrrg drain your tank
Ouch --- You need to get that stuff out of your tank!!!
Mineral spirits are basically a very light weight oil, about like lighter fluid. --- Not good.
Drain the injection tank and run a bit of water and detergent through the system to clean the lines out, then refill with water and some alcohol of your choice.
