Old 05-07-2005, 03:27 PM
stusanders stusanders is offline
Default Results with WI on a V-8 w/Roots blower?
Anyone here using WI with a Roots blower? I have a 5.7L Chevy V-8 with a Weiand supercharger, thinking seriously about adding WI but would like to get some opinions and hopefully results before going to the trouble. I just finished tuning the set up and have noticed a strong correlation between air temps and apparent power production. On cool mornings or just after I set out on the road, it runs very well but on hot days and after running it begins to sag. I suspect this is due to charge heating, despite the air intake hanging out the hood in the slipstream. I need to add a manifold temp gauge to confirm this (drilled/tapped a hole for one) but I have to believe ADI is needed. Also, is a fixed jet system adequate? I plan on piecing together a system from CoolingMist unless I hear to the contrary. Does anyone know what the ADI system looked like on the WW2 aircraft engines? Wonder if it was a simple on/off or if it was demand metered.
Old 08-07-2005, 11:44 PM
Shaker666 Shaker666 is offline
Default Re: Results with WI on a V-8 w/Roots blower?
Not sure about the ADI or CoolingMist systems, but that Roots blower is definitely not helping your air temps. If the boost is higher than 5 psi I think the temps are too high due to blower efficiency.
'71 Mustang - C90E 408W @ 9.6:1 CR, N/A
'89 5.0L Mustang: Dart block based 2.2L Blowzilla supercharged combo @ 8.5:1 CR
Old 13-10-2005, 03:43 PM
Rootzz06 Rootzz06 is offline
I am running a Eaton 112 hybrid roots.are you running carb or FI,do you plan on spraying into the s/c or after it?I saw a really cool setup on this forum from a guy who made a plate under his eaton s/c.I am new to WI but I am spraying through the s/c just before the TB.also I think that intercoolers are now available for the 6v71 style roots s/c.either way,IMO WI would definately help your situation.
Old 13-10-2005, 04:58 PM
I'm running EFI on my supercharged combo, but I've built some potent carbd combos too. Regardless, I wouldn't spray water before the blower. The mist will most certainly eventually corrode the rotors and destroy the teflon seals, if equipped. WI on positive displacement blowers is most certainly a post-discharge thing.
Old 14-10-2005, 11:29 PM
I had reservations about setting up my WI before the s/c.The reason I thought it would be ok is because of the setups I see with the carbs on top of the supercharger and I thought since the fuel (gas and alchohol in dragsters)passed through the s/c in those setups that my setup would not cause any harm.I also liked the idea of the cooler air going through the intercooler that is under the blower.I have only had this installed for about a week.A guy with a GTP on this forum has a plate under his eaton fabbed for the WI that looks really cool.BTW I will also be spraying a 100 wet shot of nitrous through the s/c.Are you sure that the way I have this setup isnt good?Thanks for the heads up--JA
Old 17-10-2005, 08:55 AM
I'm sure that spraying before the blower will work, but durability will be suspect. The compressor should really only be compressing air, nothing else, IMHO.
Old 21-10-2005, 02:28 PM
I have a few thosand miles on the setup now and all seems well.A combination af NYC traffic and numerous blasts and top end runs.I would like to take a look inside the s/c but that is too much work.I have been putting an average of 3/4 gallon through the s/c per day.If there is going to be a problem,I'll find it!I put about 700 miles/week on the car.
Old 21-10-2005, 07:33 PM
bripab007 bripab007 is offline
Quite a few folks in the Miata community that're running 1.2L Whipples and MP62 'chargers using pre- and post-'charger WI quite effectively.
'91 TD04-13C Turbo Miata
Old 22-10-2005, 05:33 AM
While both pre- and post-charger WI will effectively facilitate power production, pre-charger WI will degrade rotor integrity over time. Pre-charger WI will not be as durable a post-charger WI. It may be negligible, however, considering that the WI only kicks in under heavy throttle.
Old 22-10-2005, 11:53 PM
One guy who is/was running a custom MP62 'charger on his Miata called Magnuson to ask a few questions. This, and the max blower RPM were a couple of the questions he asked and was told pre-blower injection had a negligible effect and above 20-21k RPM was when things would start to come apart on the blower: he had been running 22k RPM for quite some time
