Old 23-07-2005, 07:53 PM
2k2SilverBullet 2k2SilverBullet is offline
Default Should I do Pre-supercharger or Post-supercharger
which do you guys think would be the best way to go for my mustang?
Also do you guys have trouble with water puddling in the intake tract when the injection begins and bounces of the intake tubes?
Im getting ready to install it on my mustang so any help would be helping. I have a CoolingMist WI which is knida like a Aquamist 1S system, however i will be getting the Snow Performance Variable Controller
02 GT w/ Paxton 1000
Old 29-07-2005, 08:27 AM
Default Re: Should I do Pre-supercharger or Post-supercharger
I'd reccomend pre-turbo if your 'stang doesn't have an intercooler of some kind. "Wet compression" is generally regarded as a good thing, IIRC.
Old 11-12-2006, 02:04 AM
chuckerants chuckerants is offline
I have my WI just at the dummy throttle body waaay after the Eaton supercharger. Though some people do have the WI before the supercharger to cool the compressor as you start increasing boost.
I know that the Eaton is not very thermodynamically effecient, so that's probably why it helps to cool the SC. However, IIRC, a centrifical SC is more effecient isn't it? Also, how much boost will you be running?
99 Mazda MX-5 - FFS MP62 hotside, JR Powercard Pro, e-Cool, BTB, FFS Fuel Rail, Aquamist WI, FM springs, KYB AGX, Azenis, HDSDD, 200HP+
