Old 21-08-2005, 12:40 AM
gunzo gunzo is offline
Default engine temp increase with prolong methanol use??
went on track initially without spraying due to pump fault and engine parameters were normal..
finally fixed the pump and spraying 50/50 meth/water.. 4 minutes into the lap my water temp just shot up..
someone mentioned methanol could be the cause, but i was thinking if its used for cooling charge air most of the methanol would have evaporated prior to entering the cylinder.. unless it burned before reaching the cylinder ?? :?:
Old 21-08-2005, 01:56 AM
I would eliminate the obvious suspects first like possibly a blown head gasket. If you have a head gasket leak into the cooling system your radiator will go nuclear in a matter of minutes as the cooling system is pressurized by the exhaust gases.
That or a stuck thermostat.
Unless your somehow going lean I can't imagine how the WI could increase engine temp.
