Old 07-09-2005, 02:35 AM
GotH2O GotH2O is offline
Default 50/50 methanol-water Vs. water
at 12.5afr and same running conditions for the 2 mixtures,
will water allow as much timing/boost as the 50/50 mix?
Old 07-09-2005, 10:29 PM
Will_emt Will_emt is offline
I'll take a flyer at it based on our findings with Meth ratios. Answer on timing = yes. The greater the methanol content the more it counteracts the cooling effect to a degree and in-cylinder temps increase a bit more. Dont know about the boost though, but since water has a greater density, I should say yes?
Be interesting to find out whether anyone concurs
Old 10-09-2005, 03:48 AM
KCWRX KCWRX is offline
from my personal experience with my wrx, I say NO. I recently went to straight water from a 50/50 meth mix. I have had to back the timing Quite a bit, add fuel and lower boost. MY WRX does not like plain water much compared to methanol. I have a 18g turbo/fmic, afr's w/ meth were at 11.7:1. I'll be back to the dyno for some water only runs, but for now I'm on a street tune and it is definately not as strong.
18G WRX 358whp
Aquamist 2d
Old 12-09-2005, 03:56 AM
I've seen a couple of sources that indicate that with a "proper tune" you can actually make more power with water only -----BUT ------- that tune is a very agressive super lean AFR tune. Very bad juju if things go even slightly wrong.
The methanol ratio in effect changes your effective ignition timing as by adding and subtracting methanol you change the engine's need for ignition advance slightly.
From what I've seen you can get a wide range of water alcohol mixes to work well if you tune for the specific mix. Many people use the 50/50 mix for the simple reasons that it is easy to mix, it is well documented in the various sources and seems to get the job done even in very cold weather as it has a low enough freeze point to not be a problem for any but the folks in the extreme north latitudes.
In specific answer to the question, --- probably yes, but you may need to re-tune some as you change mixtures. To make the same power on water only you generally need to run a leaner fuel mixture to counter the higher cooling effect of the water.
Old 13-09-2005, 03:16 AM
I'll be at the dyno tuning the straight water tomorrow. I'll be sure and post the results on here, w/ 50/50 and without. Weather is very similar to my last run, it was 338whp (92 pump gas). I'm going to try for as much hp as I can get, I need it
18G WRX 358whp
Aquamist 2d
Old 22-09-2005, 11:15 PM
Well, at the dyno I ended up putting down 322whp on straight water, 338 with 50/50 (from another day). This time around it was 100% humidity and in the 80's so it wasn't the best conditions. The dyno has new software since my last pulls as well, though that shouldn't make a difference in the numbers. I tuned to 11.7:1 as I feel quite safe on that.
18G WRX 358whp
Aquamist 2d
Old 23-09-2005, 11:39 AM
AndrewC AndrewC is offline
KCWRX don't suppose have any numbers without any WI do you?
Andrew...
Old 23-09-2005, 01:32 PM
JohnA JohnA is offline
Shame you didn't do any tests with lower methanol content, say 10-15%
In my experience the 'methanol effect' is not linear, even a small percentage has a disproportionate effect in power, then it tails off.
I suspect that it might be also helping the water and the fuel atomise better, sort of what some people claim for acetone.
As for the AFRs, you really have to go into the 12s for these setups to shine.
I've found that running richer than 11:1 actually LOSES you power when you use water injection.
It's all-or-nothing :lol:
Cheers,
John
www.max-boost.co.uk
Old 30-09-2005, 11:45 PM
tici tici is offline
I first tuned the car using water alone and an AFR of 12.5, then switched to 50% ethanol. On the road you could feel a difference (more power or more "happy engine" somehow).
I then tried different timing curves and find out I could run more timing when using more mix, this to have zero knock retard.
On the dyno... surprise! Timing and mix quantity had no influence on the power. Not a single HP!
Right now I run the lower timing for max power with the minimum amount of water/alcohol. The wideband shows about 12:1
Actually it's 6GPH and 17* timing advance (this for a 98 LS1 engine).
Stefano
98 Convertible Trans Am
MODS: SC raptor hood, 35th decals, Vortech V9 G-Trim SQ, homemade water-alcohol injection, Corsa catback, Eibach springs
DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
Old 08-10-2005, 04:46 AM
A 10wt% methanol in water reduces the surface tension of water 25%! The effect tapers off as the methanol content increases
