Old 16-10-2005, 11:22 AM
Badger Badger is offline
Default LIGHT TO SHOW PUMP ON
i whant to have a light to show pump has come on as on aquamist site but they show using a LED can i use a halfords 12volt warning light
Old 16-10-2005, 11:39 AM
JohnA JohnA is offline
Default Re: LIGHT TO SHOW PUMP ON
I'd stick to a LED mate, it's bright, small, easy to fit and doesn't burn out.
Cheers,
John
www.max-boost.co.uk
Old 16-10-2005, 03:47 PM
janis janis is offline
I'm with JohnA, use a LED.
I used a nice blue one (blue = water :lol: ), next to my boost gauge, so I can see exactly when the boost switch is activated.
There's a picture over here:
http://s40concepts.net/forum/index.p...art=0&count=15
Scroll down a bit for a picture with the ignition on.
Old 16-10-2005, 08:54 PM
ok thanks
Old 17-10-2005, 12:51 PM
yeah, mine is similar :smile:
big blue LED next to the boost gauge. You can see it with the peripheral vision, and also gives you an indication that you've passed that boost threshold
Cheers,
John
www.max-boost.co.uk
Old 29-01-2006, 12:57 AM
keithmac keithmac is offline
I used a blue LED from farnells with a 1k inline resistor, I think the bulb will draw too much current and could stop the pump working altogether (it`d ground the trigger wire).
