Old 19-11-2005, 06:11 PM
sdminus sdminus is offline
Default Rx7 ??
What percentage water to fuel are people using for a twin turbo application twin rotary. atm im using 5.9gph with 36gph of fuel. I am gonna be increasing my fueling to 44gph. What do you think my water percentage should be.
Scott
RX7
Old 28-11-2005, 08:15 PM
We normally go for between 10-15% of water/fuel by mass, minmise any blow-by to the sump.
Fuel has a density of 80% of water, but it is OK to go by volume, it is useful to compensate the pressure offset in the manifold.
Could we have more details of the set uip - pictures will be useful.
Old 18-12-2005, 07:42 PM
Cool thanks. What details would you need.
Scott
RX7
Old 18-12-2005, 10:10 PM
I think the Rx7 have primary and secondary injectors, what are their sizes?
Old 18-12-2005, 10:22 PM
Im am going to have 2 x 850cc primary injectors and 2 x secondary injectors
Scott
RX7
Old 20-12-2005, 10:52 AM
YOu are capable of deliverying 3400cc of fiel per min. a 1mm just will about giving to 10% of w/f ratio. If you add a priming pump - you can stretch the ratio to 15%+.
How stressful is your tune (engine wise)?
Old 20-12-2005, 10:01 PM
Cool. That was what i was thinking.
My engine is not mapped yet. still waiting for bits to turn up at the mo. Gonna tune for the water and try and gain a few ponies tho the timing.
How does the ratio alter when adding alch if at all.
Scott
RX7
