Old 28-02-2006, 12:03 AM
maxc maxc is offline
Default size of water&temp
Smaller water particle makes more power. :lol: 10% more tested by g-tech.
Old 28-02-2006, 10:10 AM
JohnA JohnA is offline
Any more specific data wouldn't go amiss.
How did you measure the particle sizes anyway?
Cheers,
John
www.max-boost.co.uk
Old 01-03-2006, 12:39 AM
Injection tube is 12 mm in diameter. Water is not visible when it exist. Flow rates are 50 to 150 ml per. min for 400hp engine. None turbo 351c . With no timing change. 40 more hp. :shock:
Old 01-03-2006, 09:55 AM
Hard to see what sort of particle size we're talking here.
What was the pump pressure and what was the nozzle size?
Cheers,
John
www.max-boost.co.uk
Old 01-03-2006, 02:06 PM
Default size&water temp
1 1/2 psi. 034 nos jet. Injected under carb.
Old 01-03-2006, 03:20 PM
1.5 psi is negligible pressure, can you really inject fine mist with that?
Do you mean 1.5bar? (still low though)
Cheers,
John
www.max-boost.co.uk
Old 21-08-2011, 01:24 PM
Default Re: size of water&temp
After 4 more years of BS. Just found out my g-tech under estimates rwhp.
You need the right volume of steam and temps need too be controlled.
