Old 03-03-2006, 10:42 AM
slostar slostar is offline
Default shurflo pumps - pulsing fix
this may have been done before. but; after not liking the way the pump plused on and off on the presure switch. i came accoss cheap, simple dc motor controler kit. now i can vary the speed of the motor and set the speed so it holds just under the pressure switch threashold. witch = no more pulsing and nice even pressure . im sure the kit could be modified to make a variable presure system as well.
may be helpfull to someone..
heres the kit i used, altho i brought it localy for almost half the price:
http://electronickits.com/kit/complete/motor/ck1400.htm
Old 17-03-2006, 02:06 AM
This is a very good post for many of those who uses Shurflo pump with a demand switch. We put by-pass valve to overcome this pressure spike problem.
Your method will be excellent for a fixed rate injection system, but difficult to hold a steady pressure without some kind of feedback loop.
Nevertheless, it will help 90% of the fix delivery system.
Old 17-03-2006, 05:30 AM
simple simple is offline
Have to remember that with this type of controller your time for W/I system to response (turn ON) will be increased due to pump taking longer to reach operating pressure.
It will need to be activated a bit earlier to compensate?.
:roll:
Old 17-03-2006, 10:03 AM
yeh, i was thinking of using a pressure regulator of some type, and/or a check valve with a high cracking pressure, returning back to the tank. but thought i'd give this a go insted. it isnt perfect but works and doesnt cost alot. the respose time seems to differ very little, than without the controller on it. almost instant. (with water in the line of course) found i didnt have to turn the pump speed down all that much to stop it hitting the presure switch, just a matter of setting it while the car was running, as the extra voltage from the alternator was enough to rase the pump speed.
Old 17-03-2006, 11:38 AM
busky2k busky2k is offline
I thought something as simple as a Shurflo Accumulator would do the trick!
Old 17-03-2006, 04:16 PM
NAnderson NAnderson is offline
BINGO!
Exactly what I was thinking even before I opened this thread. It might not have been designed for water injection, but damn if it doesn't work perfectly for this situation.
Over the years I've found that employing the "KISS method" eliminates a lot of headaches.
Old 17-03-2006, 08:28 PM
redvictor redvictor is offline
BINGO!
yep,accumulator works great....
Andy Frost,driver of the Worlds fastest, and Europe's quickest and fastest street legal car
0-60mph,1.0secs,
0-208mph 3.96 secs
0-263.7mph 5.87 secs
Old 18-03-2006, 04:01 AM
Is it an air or water accumulator been used?
Just thinking if it is an air type it will cause a plenty of overspray after the pump turns off, unless you have flow valve/solenoid.
Old 18-03-2006, 10:21 AM
yup, this is just another answer to it thats all. i thought i'd share
Old 18-03-2006, 12:33 PM
100cc water accumulator.........
0-60mph,1.0secs,
0-208mph 3.96 secs
