Re: New Install STI failsafe issue
yes, quite easy. You can just solder a bare wire across the resistor.
So I did the soldering and now the b light stays on all the time. I assume that's normal? Do my wl limit failsafe still work?
This means the WL lower limited is reached. This is why we put a lower limit with the resistor. I have warned you about this,
I see. So now there's no low WL limit, meaning if I get a blockage the failsafe won't trigger?
This is correct. The moment the "B" led lights up, the WL is disabled.
Do your x1.5 pre-amp configuration, things will change for the good. |
