Old 18-06-2012, 07:57 AM
crum86 crum86 is offline
Default Do I need a restrictor??
Finally got the system up and running today and did a manual test with the jets installed in the intercooler pipe and there seems to be a LOT of water being sprayed in.
The engine is a Nissan RB30 which is running 6 x 750cc injectors and about 22psi of boost (might wind up to 25psi with water/meth). The car is making about 530hp at the flywheel currently. I plan on running a 50/50 water meth mixture.
I've installed 2 x 1.0mm jets in the intercooler piping post intercooler. Do I also need to fit one of the restrictors which came with the kit?
What I've worked out is:
750 x 6 = 4500
4500 x 20% = 900cc
1 x 1.0mm jet = 450cc @ 140psi (165psi - 25psi boost)
Total of 900cc means I need to fit a 0.9mm restrictor in the FAV??
Old 18-06-2012, 08:15 AM
Default Re: Do I need a restrictor??
At 900cc/min, I would leave the restrictor off at this stage so that you don't limit your maximum flow.
Old 18-06-2012, 08:52 PM
Does it run the system flat out when you activate it using the test jumper? Just that there was a fair volume of water sitting in the pipe after a pretty short amount of time(was disconnected from the engine to test the spray). Will the water atomise more with boost pressure running through the system?
Old 18-06-2012, 10:29 PM
The system should run flat put with test jumper.
Please explain the second question, I don't understand it fully.
Old 19-06-2012, 01:32 AM
The boost pressure will break up the spray of water so it doesn't concentrate on the one area so much and make it pool
Old 19-06-2012, 07:27 AM
I see. Under boost conditions, air speed across the nozzle will help dispersing and breakup the droplets.
Old 19-06-2012, 07:37 AM
I'm just looking through the manual again and the flow chart for selecting injector size is different to the one on the Howerton Engineering site. There is a fair amount of varience so I'm a little confused now. Seems like the 2 x 1.0mm jets are way too big. A 0.8mm and 0.9mm combined equal 898cc of flow
Chart from manual
Chart from Howerton Engineering
Old 19-06-2012, 11:22 AM
one is compensated. It allows system loss. It makes life easier for our users. Use the one from Howerton.
