Old 10-01-2014, 07:35 AM
kellygnsd kellygnsd is offline
Default Flow sensor pulse output
What is the max pulse frequency output for the turbine flow sensor? I need to know if I can wire this directly into my ECU. Thanks
Old 10-01-2014, 09:07 AM
Default Re: Flow sensor pulse output
The frequency span approximately between 10Hz to 400Hz. You need to calibrate your own flow table against frequency.
Old 21-01-2014, 12:31 AM
Thanks Richard
