Hello I have a Motorcycle and when the Aquamist system is on and the bike is running the system leaks a few drops of water every 3-4 seconds or so, the system is new and used only one time..you can here the pump click every 1-2 seconds or so..
Any ideas?..Oh Richard where are you :twisted: John |
I would like to know more details of the current problem:
1) Does the system dribble with the HSV activated or idle? 2) Does the comes out of the jet of the quickfit connectors? 3) Are the nylon hose held down on non-vibrating components. 4) Same question for the HSV If possible, send me a few pictures for the various componets fitted.
![]() Quote:
Number 1 yes Number 2 ? ? dont understand? Number 3 yes. Number 4 again it leaks even when the bike is off and the key is on. |
sorry, I meant to say:
2) Does the water comes out of the jet or the quickfit connectors? I will await for your test results of the HSVm it seemed that there is some small debris trapped on the valve seat.
![]() Quote:
Thanks again !! John |
I will ask for a replacment valve send to you via one of our distributors so that you will be in good shape on Sunday's second attempt to break the current speed record.
Good luck, I will report back on the leak valve once I get it back via the post.
Thanks Richard, this is about the best customer service I have seen, only thing better is if I can get you to come over and beauty of the install :mrgreen:
Thanks John |
