Old 21-08-2008, 02:33 PM
Daxcossie Daxcossie is offline
Default Rich AFR's when running 50% Methanol Water Injection......
I decided on running with a 50% methanol mix and my AFR's have gone way too low.
Set-up is on Race Aquamist Pump, single .6 jet on inlet size, activates @ 40 degrees / 14psi.
I will have to go back to using distilled water only as the AFR is too rich as soon as the methanol get injected into the system.
http://i5.photobucket.com/albums/y17...ie/alex2-3.jpg
Arranging Insurance cover for customers since 1975 " www.sheraton.uk.com "
Old 21-08-2008, 10:11 PM
keithmac keithmac is offline
Methanol is a fuel, you need to either re-tune the car leaner on the fuel injectors when the WI is active or go back to straight water.
If you tune for methanol, you need good safeguards to prevent a lean condtion due to any fault in the WI system.
