Old 23-10-2013, 10:07 PM
Default Re: Wiring issue
Make a "resistance" measurement between 1&2, 2&3
Old 23-10-2013, 10:14 PM
bulldogface bulldogface is offline
is seems like there isn't any connection between, reading is zero, and connection test between red pin and either of fuse pins is negative.
Old 23-10-2013, 10:18 PM
just ran test of suggested points with two meters. between 1 and two, zero. between two and three, 6.6 ohms..
Old 23-10-2013, 10:19 PM
with the circuit board off the car, we can examine the copper tract easier. Do make the above measurements and I will make another picture meanwhile.
Old 23-10-2013, 10:38 PM
It is strange to see 6.6ohm between 2&3. Follow the copper track run, it should be continuous. Examine it closely.
Old 23-10-2013, 10:52 PM
It appears the red track is broken. (2&3)
Blue track ...... circuit board bottom
Red track ........ circuit board top.
Old 23-10-2013, 11:04 PM
Old 23-10-2013, 11:17 PM
seems like there is tiniest of circuit bubles, plus some black residue around the first solder point of capacitor, going thru hole. tried to make a pics of it, but i am not sure they're going to help...[IMG][/IMG]
Old 23-10-2013, 11:18 PM
part between capacitor and fuse is nice and clean.
Old 23-10-2013, 11:26 PM
Can't see the image. Post it to richard AT aquamist.co.uk
It looks like there was a spark created some time ago where the black is. Hence burn out the track.
If you can solder a bridging wire between 2&3, it should work normally after the repair.
