Old 22-05-2012, 10:16 PM
ian spark ian spark is offline
Default Wiring issue
I am trying to install this system in my car. It's an 06 Subaru sti but im having some issues. I have everything hooked up according to the wiring diagram but it doesn't seem to be getting a single from the injector. Do you have any idea what might be causing this?
Ian Spark
Old 23-05-2012, 12:36 AM
Default Re: Wiring issue
Does the green led blink on the controller?
Do you have a digital voltmeter?
Old 23-05-2012, 01:12 AM
The green led does not blink. I can probably track down a volt meter.
Old 23-05-2012, 08:16 AM
Once you have the voltmeter, please let me have the readings on the following test points of the controller:
TP5, 8, 23
Black probe on ground pin (bottom left)
Old 24-05-2012, 02:33 AM
I checked the test
Old 24-05-2012, 02:34 AM
Points you said and they were no5 13.76v no8 13.76v no23 13.7v
Old 24-05-2012, 08:15 AM
Looks good so far.
The next step.
Please tell me what you see on pin 5 and pin 8 when you blip the throttle.
Old 24-05-2012, 07:28 PM
When I blip the throttle the voltage drops about the same for both of them
Old 25-05-2012, 07:38 AM
Pin 5 should be quite steady when blipping the throttle. Check the red wire of the grey harness is connected to a steady/fixed/switched 12V source.
Old 25-05-2012, 03:47 PM
I had a look at it and it is connected to the most steady source I can find it moves around about .05v when I blip the throttle is that good enough
