Old 22-10-2014, 07:00 PM
FrisbeeGTI FrisbeeGTI is offline
Default MAP minimum treshold voltage
What is the minimum voltage from MAP-sensor (output 0-5V) to be sensed as a trigger threshold for Aquamist? (0.1V? 0.2V?)
Old 26-10-2014, 01:08 AM
Default Re: MAP minimum treshold voltage
It is:
(referring to the MPS solder link)
0.6V for A setting
1.2V for 3 setting
1.8V for 2 setting (default)
Old 30-10-2014, 03:27 AM
It is:
0.6V for A setting
1.2V for 3 setting
Ok, thanks.
On the other side, what is the highest voltage of the MAP sensor output voltage scale to be used as a trigger point? 4v?
Old 31-10-2014, 12:53 AM
12%-72% of boost range.
A: 0.6V to 3.6V
3: 1.2V to 3.9V
2: 1.8V to 4.1V
