Old 15-12-2009, 11:22 AM
Default Water anti-freeze
Hi,
what would you use as water anti-freeze in a plain water injection setup ?
Thanks.
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Old 15-12-2009, 09:20 PM
keithmac keithmac is offline
I think methanol`s a good bet, maybe 20% as this shouldn`t drastically affect your tune/AFR`s.
Old 20-12-2009, 10:55 AM
Will try, thanks...
Old 30-12-2009, 04:54 PM
Just a question... is HFS-5 system meth ready ?!
Thanks...
Old 31-12-2009, 01:09 AM
Best check but I`m sure all the systems can take a 50/50 mix of wter and methanol?.
Old 31-12-2009, 03:11 PM
Thanks...
The Shurflo pump is methanol resistant (the "R" word), Unfortunately, prolong use of methanol will make the internal seal shrink, in time It will leak. For 100% mehtnaol, it last about a year. For 50:50, it is about 2 years. We have all the spares are available, it it not too costly, around $20-30 per item. normally you need to replace the #10 component (?30).
Old 03-01-2010, 12:51 PM
Ok, thanks!
