Old 02-07-2015, 09:55 AM
jsluck jsluck is offline
Default High speed valve
Hi,
I have the attached on my car. I had to take this apart to remove some hose, but I'm not sure if I can refit it with new hose? It seems to be a pressure fitting, but no idea how to refit, as it does not seem to simply click into place. Was it meant to reuse a new clip every time?
I realise to no longer make this part, so worst case, what part would I need to replace this with?
Thanks,
John
Old 02-07-2015, 05:26 PM
Default Re: High speed valve
Is is difficult to see the hose. Unfasten the HSV and I 'll be able to give you some directions how to remove the hose from the HSV. It is most like it is jammed solid. may require a new fitting. Let's remove the hose first.
Old 03-07-2015, 08:51 AM
Hi,
Sorry, I've maybe not explained that well.
I have removed the hose already, but cannot refit.
More pictures:
https://goo.gl/photos/5wQvGwts8R1jYitu6
I've unscrewed the fixing from the HSV. My problem is I am not sure on how to refit the hose into the fitting. I did not want to brute force it for fear of damaging it.
Thanks,
John
Old 03-07-2015, 08:54 AM
The fitting is damaged, you need to order this one:
http://www.aquamist-direct.com/806-3...-qty-discount/
Old 03-07-2015, 03:03 PM
Excellent, thanks a lot
John
