Old 24-05-2015, 07:07 AM
parmas parmas is offline
Default Re: Experience of isopropyl - good read (long)
Corrosion and rubbing alcohol
http://www.123helpme.com/view.asp?id=85097
According to the article above rubbing alcohol consist of :
Rubbing Alcohol Components
Isopropyl alcohol is a clear, colorless liquid with a somewhat bitter taste and a smell of acetone. Rubbing alcohol contains:
v 70% Isopropyl Alcohol
v Small increments of water
v Methanol,
v Ethanol,
v And/or ethylene glycol.
So rubbing alcohol is not 100% isopropyl but a mix of alcohols !
. Corrosion and Rubbing Alcohol
Because the rubbing alcohol has some amounts of water in it, as well as a ?stripping? component, (used for eliminating germs), I believe that testing the different metals in solutions of alcohol instead of just plain water could actually increase corrosion.
There are also hydrocarbons in the mixture of rubbing alcohol. Hydrocarbons are basically bonds of hydrogen and carbon.
Hydrocarbons can also assist in the progression as well. Just as salt water helps speed the process, a product that has added strength such as the Isopropyl alcohol should aid with the corrosion?s speed in the different types of metals.
Old 04-09-2015, 10:54 AM
This is good one to show the speed of burn with varies concentrations:
https://www.youtube.com/watch?v=pxC8p439isU
Old 04-09-2015, 01:57 PM
Funny but good video....
It would be nice to see Methanol / Ethanol / Isopropyl head to head
Old 07-09-2015, 08:05 AM
The demonstration is excellent how water can change your burnt rate.
But don't forget it have to applied to all the fuels going into the engine.
Old 17-09-2015, 08:01 AM
XenonLED
That is sounds very good.
oneplus 2 schutzh?lle
Old 30-07-2016, 10:42 PM
jmlegacy jmlegacy is offline
The only way I'd use Isopropyl is when nothing else is available.
Right now i'm seeing where it can add tiny amounts of octane and help with fuel atomization.
Old 14-03-2020, 01:38 PM
MadisonCarr MadisonCarr is offline
Read ExtraEssay Reddit reviews before ordering a paper. Find out the pros and cons of this writing service. https://www.writingpapersucks.com/ex...ay-com-review/
